Ivan in southeast va.
Snyder's sell a 2 rivet gas cap. Helps to keep the gasket from sliding around and blocking the vent hole.
A couple quick things that came to mind reading your current post:
In chasing down my recent issues, I found one of the studs in my terminal box was loose.
I found old splices in the shielded wire from the switch to the distributor.
I have recently read that often a failing switch can be identified by jiggling the key with the engine running or when cranking to start. If engine running try turning it off and if it goes off as you start to turn it rather that after your turn it (at the end of the distance) it may indicate a bad switch. This is true on aircraft switches as well and there, I have seen this 4 times in the last 50 years. One of those planes was heavily damaged in the landing on a road!
We have a model A that the engine dies on while driving. It is a new rebuild that has about 750 miles on it now. At first when I got it back it was hard to start. I eventually figured where spark & throttle had to be to get it to start. Last week while on tour it died about 8 times. Did so on another day also. It acts like the gas has been shut off. Once it dies it seems like the only way to get it to run again is for it to be pushed & pop the clutch. This morning I checked the gas flow out of the shut off & it looked good. I pulled the gas line to the carb & it looked good. I checked the carb to manifold bolts for tightness, good. I checked the manifold nuts & they were good. It cranks good once it dies, it just refuses to start. Club members checked the spark while I cranked the engine with the starter & they said there was spark. It just seems to be lack of gas. I also blew air through the vent in the gas cap. I'm lost at this point & afraid to take it out again. More ideas would be appreciated.
Thought of another past head scratcher to share.
Harbor Freight AG glass fuses that look good but are not connected well internally. Once again they pass visual inspections….
I left my key on once with the points closed and the coil got so hot I couldn't touch it. I let it cool down for a couple of hours and the car started right up.
I drove for about 5 blocks and it quit. I had to walk home and retrieve another coil. I installed it on the side of the road and no more problems.
