pistonburner
Hey gys i have a 41 flattie that cuts out under just when it starts to pull good, when it is sitting you grab the throttel and almost but not quite half way it starts cutting out. I have replaced the coil even put a divorced coil on it changed the pionts changed the plugs checked all wiring from switch down to coil. engine has around 900 miles on it has fresh fuel good compression and good fuel presseure. I have done everything i know to not that i know everthing. HELP
