Bob, There should be lots of them around.
They varied over the years so you need to specify your year.
Mark at Model T Haven will have originals; https://www.modelthaven.com/
You can start by replacing the sleeve that it fits thru. Not an easy job but most are well worn. You can also weld up the worn area on the crank and file back to round. I does not have to be perfect.
