I have a road draft tube off a 55 club sedan you can have. It had a pcv valve in the top hose fitting and the bottom of the tube is cut cut straight instead of at a 45 degree cut. easy to change back. get to me your address and I will send it to you.
Cheers Jim
The T-Bird engines with Y-block had a blanking plate where the hole is at the front driver side of the engine, but they added a tube in the back that wrapped around and terminated in the rear of the valley pan. All Y-blocks had positive crankcase ventilation. Y-blocks were discontinued in cars in 1962 and 1964 was the last year for the truck 292 Y-block.What year did Ford delete the holes for road draft tubes on the Y blocks?
Thanks again for all the help.
I'm not sure when it happened but I looked at a '64 pickup with its original block (as per the owner) that did not have a hole in the left front side of the casting for a road draft tube.What year did Ford delete the holes for road draft tubes on the Y blocks?
actually Ford introduced a PVC in '61 on some engines. My '60 292 had road draft before I changed to PCVThe T-Bird engines with Y-block had a blanking plate where the hole is at the front driver side of the engine, but they added a tube in the back that wrapped around and terminated in the rear of the valley pan. All Y-blocks had positive crankcase ventilation. Y-blocks were discontinued in cars in 1962 and 1964 was the last year for the truck 292 Y-block.
Emissions control devices were not employed till somewhere around 1970.
Federal mandate for auto manufacturers to install seat belts did not take effect until '64.
Oh, no, we didn't have air-bags, computerized ignition, fuel injection, bluetooth connections either? However did we survive ??? (sarc)
