As noted there are no cam bearings. I assume you have measured the existing bores and the cam and that there is more clearance than you want. The stock bores were 1.560. Acceptable, but not good, diameter for the cam bearings is 1.557. Is your problem the cam, if so, first search for a better cam. If it is the block, it can be align bored out to whatever size you want for an oversize cam, or, bored out to any size, install bushings, and then as James says align bore the bushing to the size you want. That is what is possible.
What is practical is something else. Finding someone who would do the work for me was tough and when I found someone it was expensive for what I thought was a fairly simple job. The rebuilders of modern engines around here told me they did not have the equipment to handle an A block. Maybe they just did not want the job, don't know. The guy who finally did it explained all the problems he had getting the block in his machines and the time it took. He did a good job, things are fine, but Wow. First measure, then call around.
