oljoe001
Hi I have completely gone through my motor. 4 blocks to find one that wasn't cracked bored 060 over new pistons rings, new valves and seats (stainless) tour grind cam by the way what is the difference between stock and tour grind lift and duration? also high volume oil pump (the shaft size is smaller to allow more oil) balanced crank (from Ron's Machine shop in Ohio) lightened flywheel with v8 clutch Babbitt by Ron's Machine which was recommended by Snyder's Antique Auto. Pressurized center bearing and rear bearing oil return larger. high compression head 6.1 with stock Zenith which I made sure all jets are sized correctly running a car gear in rear end. Also stock authentic muffler. my design of floating motor mounts. The truck drives fine at 55mph barely into the throttle. I did not mean to drive it that fast but found my speedometer was off by 9 miles per hour @ 40 mph So My main question is... will It hurt my motor (Babbitt's) to drive it like that?
also how does the timing affect the life of the Babbitt's?
any information On those 3 questions would be appreciated.
thanks
Joe
thanks
Joe
