Earle
I just had work done on my engine (new insert rods, rings and cylinder honing). Refer to my earlier post about "rod bearing failure". This work, of course, calls for my having to go through a "break-in" period all over again. But I've heard, over the years, two very different philosophies about the break-in "technique".
One - My trusted engine restorer (who shall remain nameless so as not to bias your answers) - says to drive her gently, accelerate more slowly, NO LUGGING, stay under 40 MPH, change oil after the first 200 miles, etc. And do this for at least 500 miles. Violating these "easy break-in" precautions will result in poor ring seating and possibly scored cyl. walls. (35 MPH for 500 miles!...uugghhh... there goes my touring summer season...)
Some other "reputable sources" and "experienced A folks" (did I hear this in the Barn?!) say that the break-in period should be only about 100 miles during which you should drive it "hard", including up hills, high acceleration, etc. This causes the new rings to seat harder against the newly-honed cyl. walls and results in a faster, better seating and break-in.
My gut feeling and engineering intuition tells me #1 is the right answer!
Thoughts?
Earle
Thoughts?
Earle
