In the last few tours I have found engine blow by and also loosing some water. I suspect a head gasket. Engine has only 10,000 miles on it. I plan to do a compression check. Any sugguestions? Thanks for the help.
Blow by from where? Losing water where?? Was the head re-torqued??? Any loss of power????
I think you are on the right path to checking compression. I would also suggest you consider doing a cylinder leak-down % test before you tear into it. Then our suggestions will be more meaningful but at this point, the suggestions might be to check the clutch bearings or the muffler for being plugged up!
