SGT in Ont.
My engine has started to backfire when I decelerate coming to a stop sign. I've tried re-setting the points, runs fine when cool, but starts to act up when the engine gets hot. Any suggestions?
Driving around town the GAV is about 1/2 turn open down to about 1/4. If I go out on the secondary roads where the speed limit is 50mph I have to open the GAV to about a full turn open so that it has the power to keep up with traffic.Usually means it's running lean. Vacuum leak or carb jet problems. Where do you run your GAV?
