ive been looking at my '39 transmission, had an issue with 2nd gear jumping out, the trans was meant to be rebuilt from a well known shop in the USA...
Anyway I measured the gap between 2nd gear and the thrust washer and its 0.014" so I know this needs addressed. whilst I was there I noticed the main shaft moved back and forward in the case, I thought it might be the snap ring on the rear bearing but it seems pretty tight on the bearing and there is only 0.005" of a gap between the snap ring and the groove which doesn't seem excessive. The shaft moves back and forth about 2mm - is this excessive? if it is excessive what is the best way to help remove some of the play?
