nkaminar
The return spring for the emergency (parking) brake is notoriously hard to install. It has to be pushed or pulled to hook over the arm where the rod attaches. I made a simple tool that makes the installation possible that I want to share with you all. It is the right size so that it can be leveraged against the other parts down there so that brute force is not necessary. I had to heat the screwdriver red hot to bend it. I made the notch using the cut off wheel on my Dremel. Once the spring caught on the lever I was able to snap it into position with another screwdriver.
