emergency brake carrier rod
Shoat
I have a emergency brake carrier lever. One of the new brass bushings will easily push over the ball. The other one only goes part way. I got the original bushings out and they are the same way. Does the bushing go all the way over the ball or only part way, is one ball just worn more than the other? The old ones pulled off eas
Main brake lever : each end of the lever has a small hole in the shaft. Is this normal or is this a rust out issue?
