hello
i am working on my rear brakes i need to get the e brake backing plate off to get to the brakes i have everting loose but the backing plate will not come off i do not want to bend it i do i get it loose with out doing damage to it this is on a 30 tudor
thank you
kevin
hello all thanks for the replys
yes the e brake leaver and wedge are removed the e brake shoe is removed only thing left is to remove the e brake backing plate it will not budge
Is the emergency brake toggle lever completely out? Originally, there were no zerk fittings on the lever housing and that sucker is often corroded fast.
hello
I tried to upload photos but it will not let me
Kevin
