Emergency Brake Actuating spring
Dennis Pereira
After spending hours sanding all the bumps and nicks from the toggle shafts and actuating arms key ways the spring was simple ! A little grease slip the spring on then the arm tap tap hook the spring well almost that easy . My special tool made the job easy took seconds to hook the spring .
The other side wasn't so easy until I removed the connecting link clevis pin . then the arm can move back and the spring attaches in seconds . That's what happens when I stop in the middle of a project I forget what worked yesterday .
