I'm not mikek but 750 ohm 1/4 watt should work. The output of the Alt is usually over 14 volts and the 6 v is actually closer to 7 so you have to drop 7+ volts. Allowing for some fluctuation and not driving the led at max brightness I think the above will work just fine.
