bettlesr
I also have an FSI igniton system. Mel told me the burnout proof module is effected by the ignition noise from the Model A plugs and wiring so they had to revert to the module that is sensitive to being left on without the engine running. As I have a full pressure oiling system, I have an oil pressure switch that feeds the ignition. Engine not running , the ignition is shut off. I also have a VW diesel glow plug timing paralling the oil pressure switch module set to 20 seconds so I can start the engine before the oil pressure is up.
