BUBBAS IGNITION
Best description i can come up with is "pain". Customer brings two Mallory uni-lites in the shop in a box for testing . Both test showing a defective module one was dead with no action and the other one was "hurt". Hurt is what i call it right before the electronic modules just gives up!! It will skip a cylinder under load every so often causing a terrible , hard to find miss fire....
In this case we replaced both modules but really need to know the cause.
Often ( and in this case) a low resistance coil was mistakenly used with a value of less than 1 ohm!
The replacement modules have a warning note in the box to always use a 1 ohm plus a 1.5 ballast resitor with these modules.
Most electronic units have a current limit that is built in the module as a protection measure , however it cant run for long periods of time in this protection mode as it will hurt its self with the heat coming from the higher current heat build up.
Take a good look at the coil resistance and the instructions with the modules. And always check what coil resistance is .
