Dave in MN, post #9 is correct.
Especially if you have a 6v Pertronix unit, voltage drop during starting may not letting the Pertronix unit fire.
See the below from Pertronix:
POWER & GROUND TESTS
VOLTAGE TESTS (ENGINE DOES NOT START):
1. Connect Voltmeter red lead to positive (+) and black lead to negative (-) terminal of the battery.
2. Crank engine and note voltmeter reading. Make sure that the voltage does not drop under 5.2 volts while the engine is cranking.
Check your battery, cables, connections, and starter draw if the voltage drops under 5.2 volts.
3. Attach the voltmeter red lead to the Ignitor mounting plate and the voltmeter black lead to the negative terminal of the battery.
4. Crank engine and note voltmeter reading. The voltage should not drop under 5.2 volts.
I had a similar problem years ago with my car, an under performing 6v battery, and my Pertronix. In my case, a new battery kept enough electrons flowing to the Pertronix to bring things back to life. The Pertronix unit was not damaged.
Check your voltage drops and grounds.
Hope this helps.
