BRENT in 10-uh-C
If points when set up right are as good or even better by some people belief , why don"t they put them in our new cars ? They would have to be cheaper and more reliable then electronic. Just wondering.
Actually, it is deeper than that. The first thing is Model-A engines today do not need to meet an emission standard like modern cars do. Second, compression ratios are higher in modern iron requiring a different type of coil than what most Model-A's use. Even with Nu-Rex timing indicators available, and Zipper distributors, I'd venture a safe bet that over 90% of all Model-A engines on the road do not have the correct (optimum) timing for the speed and RPM they are driving. The same can be said for fuel mixtures. Therefore having an electronic timing that is the same degrees away from optimum as a points triggered system boils down to the same. Since the Pertronix only triggers the spark (does not create a hotter spark), then the fuel combustion is the same with both units.
And, if we are to advocate the use of 21st Century technology on our restored Model-A, then how is it we are not advocating that each restored car have a padded dash installed, air bags in 4 separate areas, better bumpers, and many of the other government mandated items?
Society has "dumbed down" where people cannot install/adjust points now, --and folks were unwilling to provide proper maintenance so 'Detroit' had to figure out a way to do it for them. Our beloved Model-A has so many items that are supposed to be maintenanced on a regular interval so that adjusting a set of ign. points should be a regularly scheduled item no different than changing oil or adjusting brakes. Now please understand I am NOT saying that electronic ignition in a Model-A is a bad thing. All I am offering is the facts so that people can make good decisions for their own needs. My opinion (--based on quite a bit of experience with both sides) is that the typical Model-A engine does not perform better (i.e.: make more horsepower) with just the installation of an electronic ignition system. For those who do not agree with me, then state exactly 'why' it does and substantiate their beliefs.
