Bill in Al
Does anyone make an electronic ignition for the helment coil type distributor? Thanks
av8paul, where do you get the black caps for the Mallory?
I have run electronic distributors on both my flatheads for 12 years with zero problem. Why should there be a problem? If you have a generator instead of an alternator, you could blow out the module. I read lots of gripes about electronic distributors, but don't fortget, your family daily driver is probably using an electronic ignition flawlessly, so why shouldn't your hobby car run without problems. Mine does as well as my home car. If you are going to use an electronic ignition, be sure to use an alternator and not a generator.
