thebanjoman
Temp has very little to do with it. I just derusted a steering column in my outside tank. I had to break the ice to submerge the column. I left it in for 3 days and it was fine. Fortunately the outside temp was about 32 so the tank didn't freeze solid. As far as inside is concerned I used to have mine in the shop. As far as I can tell there is no fire danger at all, but after awhile I started noticing that I felt like I was having an asthma attach, so I moved it outside. I wouldn't put it in the house but a well vented shop may be O.K.. Maybe put it in the shop in the winter and outside in the spring. I've been using this process for about 15 years. I swear by it.
Been thinking of trying this process on wheels and the rear fenders.Seems like lot better way to remove the paint, rust, and the gobs of undercoating from the inside of the fenders.
A wooden frame with pond liner or thick mil plastic material should allow me to make the tank as large as needed. I'd use rocks at the corners to make a better form of the tank. A 'kiddie pool' would be too big and harder to dispose of afterward. I don't anticipate needing something big after this project. Frame should hold the amount water fine.
I'd have to do this in the shop to keep the neighborhood nutjobs from blowing a gasket so I'd make a cap for the tank and use the shop vac hose to vent it out the shop window so it'd be safe indoors.
Thinking out loud as most of the examples I've seen about this have been in buckets or trash cans.
