Robert/Texas
The points and condenser came, and I installed them. The small plastic bag that the points came in was marked USA, but the points are garbage in my mind. Only a little more than half of the electrodes surfaces match and I feel that they will be short lived. I’m thinking that I ought to get a modern conversion kit to replace them if no good original style points are available. Suggestions welcome.
After this I checked to see if I would get some sparks at the points with the ignition on, using a hard, wooden pointed stick. No go, so I got my other Model A out and did the same thing and got lots of sparks.
As there is voltage (6.1 volts) at the point arm with the ignition switch on, I don’t think that it is either the switch or the wiring. Comments here are welcome too.
I get 1.6 ohm reading between the coil terminals, but I don’t know if this should be any assurance that the coil is good. Again, any help/suggestions are welcome.
Thanks much in advance, Robert
