Neshkoro
I have a strange request. The speedo in my Model A stopped working. I was considering replacing it with a GPS speedometer. I had one from another project. I powered it up from the Model A battery through a little pcb that increases to voltage from 6 to 12 volts. It doesn't work! I wired it up with a 9 volt battery and put it in my daily driver and it works as it should. I wired it up with the same 9 volt battery and it won't work in the Model A. Any thoughts? Is the A producing some sort of "dirty" signal from the points or the generator?
Might there be a workaround? I thought would be cool to have the GPS speedometer!
If you think i'm crazy to try to get this to work, just let me know. I'll just get the speedo fixed! If you have any ideas on how to make it work, Ill try that, too!
Thanks!
Thanks!
