SeaSlugs
Hey Slugs it is a cheap aftermarket switch....did the 31 come with a popout switch?????
The Dash and Dome light are not wired as they should have been originally so for know i have pulled the fuse that they had on the dome light and dash light circuit. Ill get hose wired correctly after i get the drain figured out...Thanks for the info on the switch.
yes from the factory it did with the armored cable all the way to it. the cheap aftermarket is just an on off key switch with 2 brass spade terminals with screws. Those terminals internally love to get loose and make flaky contact.
The nurex "fake" popout is pretty good quality. It looks identical and mounts identically to a pop out but doesnt actually pop out. Has nice solid detentes for off an on and feels tight inside.
