Gentleman, having a electrical issue that’s driving me crazy. I have a Powerhouse gen on a 31 roadster. The gen passes the motoring test but seems to turn slowly.
Cutout is old school. The gap checks out and seems to close at around 7 volts.
The car starts and runs fine….very well even. But when I try to get a voltage reading either directly from the battery or from the starter while the car is running the reading is all over the place. Mostly it doesn’t even register….like an open circuit or short. When a number does pop up it’s anywhere from 6 volts to 12 to 2 or 1 etc. Then mostly it just freezes the meter or shorts to open. I’ve tried 3 different meters with the same results…..I’ve also bypassed the cutout, and disconnected the output wires entirely from the cutout, but with no change.
The second you shut the car off, the reading changes to normal battery voltage regardless of where it’s taken from…start it back up and the problem re occurs.
WHAT COULD THIS BE!!
It’s acting like it’s creating a electrical or magnetic disturbance the second you start the car. Theses no change when turning on or off the ignition switch when the engine is not running…..again, just with the engine running.
Could the gen be shorting to ground? Coil? Points? But the car starts and runs fine.
The car has a master on/off switch, the ammeter needle is broken off but it has continuity and is connected. Ignition switch is not grounded to the frame….not sure if it has to be. It’s just dangling as I’m waiting for a new instrument pod.
Sorry to ramble on…hopefully I explained it well enough.
Any help here would be greatly appreciated ….
Cheers
Wade
Cheers
Wade
