I am working on a new to me 31 s/w sedan. When the car was purchased the amp meter did not work at all. No movement of any kind. While I was rewiring the gen to terminal box I also picked up the starter mounting bracket and disconnect switch. Installed the switch on the bottom starter bolt and installed the switch on the bracket. Used a new battery cable that ran from the pos (ground) post of the battery to the switch. Installed a new cable from the other post on the switch to the frame completing the ground circuit. also installed a new amp meter in the dash. get in the car and the new meter is reading -10. Start the car and increase the idle and the needle moves to 0. Using my multi meter and checking both sides of the new amp meter I have a reading of 7.4 volts both side. Now I removed the cable from the pos neg side of the battery and reinstalled the original braded steel cable that went from the cross member to the battery post everything works like it should. Amp meter is at 0 with everything off and touching the brake or blowing the horn the meter moves to the negative side. Start the car and increase the idle the meter moves to +10.
Any ideas as to why this happens. everything from the battery through the switch is on the ground side. nothing to short out?
