tp79557
Hey guys,
So for the time being, I’m having to wire up a fuel pump since I have Weber carb on my car (came that way when I got it). Im running a 6 volt system, so the low pressure pump I have will work, but how would I go about wiring it? I would like for it to run only when the key is on. I can’t run it off the terminal block, cuz it’s hot all the time. Would I be able to get power from the key switch? I’m open to suggestions. I’m eventually going to go back to an original Zenith carb and get rid of the pump, when time and money allow. For now, this is what I’ll have to use. Thanks for any help!
Trent
Trent
