I recently took my A for it's inaugural run, 150 mi. after restoration. Everything ran well, except along the way a generator bearing froze up, threw the fan belt. Was able to drive home without a fan or generator since it was a cool day. I had the generator rebuilt and reinstalled.
After startup, the ammeter would register several amps Discharge at a fast idle. If I turn on the lights, then the ammeter would register several amps charging. After reading several posts on the forum, I suspected maybe my generator was improperly polarized, so I went through the steps of jumping a wire between the two posts on the cut out re-polarize the generator. No change.
I then called the shop that rebuilt the generator to ask their guidance. He questioned what the ammeter did when I turned on the lights with ignition off - the ammeter registered several amp Charging. His conclusion was that the wires were reversed on the ammeter.
I then swapped the wires around on the ammeter, and had no power to anything. I checked my wiring diagram and the ammeter was originally wired properly with the yellow/black on the charge side, and yellow on the discharge. Therefore, I put the wires back in their original positions.
When I went to start the engine to see where I was at, I had no power anywhere. I checked the voltages and discovered battery was totally dead at this point. Recharged the battery.
When I turned my power cut-out safety switch on to begin trouble shooting again, I noticed ammeter was totally pegged out (one way or the other) and smelled something hot, so I shut off cutout switch to investigate. Found that the horn wire in the harness was now totally fried.
One last check, before I came to you for help. I took the horn/light wire off the generator cut-out and only connected the wire from the starter. Started engine to see what I had - the ammeter was again showing discharge at a fast idle, same as before.
I couldn't find any info in the troubleshooting manual about a generator discharging on fast idle. Nor could I find any discussion on the forum.
Would appreciate any help or guidance anyone can provide on what my likely problem is and many thanks in advance.. The only thing that has changed since my 150mi trip was a rebuilt generator. But everything seems to be amok now. I have a new harness, cutout and ammeter on order, but would sure like to know what the root cause may be.
Is it possible all this trouble was caused by a bad generator cutout, or is it possible something is amok in my generator rebuild, or something else such as a shorted horn wire, or something else not yet identified?
Thanks again,
Gary Bergman
Thanks again,
Gary Bergman
