Dyna
I have a 1951 V8 flathead in my car. Electrical system converted to 12V. Just had the engine re-built and thought it would be a good idea to install a little tach under the dash to keep an eye on the rpms. I bought a cheap off shore tach and installed it. With the pulse wire on the -ve side of the coil the tach needle jumps all over the place,with the pulse wire on the +ve side of the coil the needle pegs at 10,000 and doesn't move. Black wire is grounded, red to fused circuit, white to ignition switch. Have missed something in the wiring? Or did I waste my $s.
Thanks.
Thanks.
