The only problem I see with your method is, if the diaphragm fails, fuel will flow into the crank case... Not good unless you want to wash the bearings...
I do agree with you when it comes to having a back up, that is why I carry a "known to be good" mechanical pump, in the vehicles I've converted to electric fuel pumps... Another reason for leaving the push rod in.
