Well, I was finally able to get back on my roadster startup after Fall Carlisle.
I tried the check valve in my setup but it did not work. So, I replaced my pump with the Airtex 8902 using an in-line setup. The engine starts and fires OK with the pump on but dies with the pump off once the fuel in the carbs is finished. Charlie NY redid the pump.
I will now try it by bypassing the electric fule pump all together, and just be mechanical. I will also check the mech fuel pump rod to see if it's properly seated in the cup of the pump arm.
Any other ideas? I did notice the electric pump dioes have to run pretty strong when I first turn the switch on to start, regardless of whether the car had been running the mechanical or electric fuel pump.
BTW, can a fuel filter thwart the mechanical pump?
