miniceptor86
I’m going to install an electric fuel pump to aid in starting after dormant periods. The installation instructions show using an positive oil pressure switch to prevent the fuel pump from continuing to run in case of an accident. I understand but how long will I have to crank do generate enough oil pressure to close the switch? That may negate the reason I’m installing the pump. Should I just switch the pump at the dash and use it to build pressure before starting or are there other ways like hooking it to the start button?
