don's 37
Hello again. I was just reading some past posts about installing an electric fuel pump. I understand that you need to install one as close to the gas tank as possible and also read that you can turn it on and off when needed. I read where you can turn it on before starting your engine to begin priming so that it saves wear and tear on your starter. So my question is, the electric pump will actually push gas "threw" my mechanical pump and into my carb? It will actually push gas through the valves in my mechanical fuel pump without damaging it?
