Electric fuel pump noise.
Use a piece of hose on the inlet and outlet of the pump. Vibration/noise travels thru solid tubing/pipe.
Bruce
This is always good advice for another reason--- you don't want hard connections to things that shake or vibrate because it can cause fittings to get loose and cause metal fatigue in the tubing.
Since it doesn't say, I'll bet it is 12v.
The pump is 6 Volt.
I will try some of the great suggestions given here beginning with a rubber mount and rubber hoses.
Not sure where I would be on my car without this forum but I sure wouldn't be this far along.
Thank you all and I will provide some results when available.
Phil
