When you cut the fuel line to install the fuel pump due you flair the fuel lines. According to Airtex they should be flared. Problem is I do not have a flaring tool
Depends on how you are connecting it. If you are using short pieces of hose on each side you the pump all I normally use is clamps. If you are using hard fittings I would use flair fittings. Ether way this is a low pressure setup.
As noted in an earlier post, using rubber hoses to connect the electric fuel pump to the gas line and filter will serve to mitigate the noise from the pump.
Thanks guys. Did not think I would need to flare the gas lines. But figured I would ask the experts to be sure so I would not have problems down the road.
Here is how I installed the electric fuel pump in my shoebox with compression fittings - easier than flared and more secure and durable than rubber hoses clamped on.
You probably know, but here it is anyway, even though you have the filter just before the pump, you should still have one up just before the pressure regulator (if you have one).
