What engine?I have electric radiator fans working off a temp sensor in the eng block. I would like to also monitor the temp on a gauge. Any ideas on how I could do this? do they make a "T" fitting that would work? Thanks Mike
If the oem temp sender was NPT, then with enough parts you can always fit a T in. I've not had good luck with T's, the lack of water flow past the sensor seems to make them read either slow or erratic. And ugly.
