With a shroud you need to have at least 1/2 inch between the core and fan, any closer and it will not pull air from outside the fan area. If you mount a fan with out a shroud, you will only pull air at the fan and the rest of the radiator has no air being pulled thru.
If you are using a electric fan use a shroud !
