Go with a Spal, they work well and are very durable. Available on line at Amazon, Summit, Jegs and many other. Available in various CFM value for either supplemental or full cooling. I installed a push 16" 3000 CFM on my '35 and put it between my grille and radiator face mounted to the front of the radiator. Can barely see it and haven't had a problem with the push type. ( liked the idea of hiding behind grill and front of radiator, JMO, but I think they look ugly on the engine side) The thermostat thermocouple will fit inside passenger side upper cooling hose and will allow the hose clamp to seal with no problem. Obviously thermocouple connected to an adjustable electronic thermostat. I put the thermocouple in the radiator hose after trying to use the thermocouple mounted to radiator fins and didn't respond quick enough but works extremely well inside hose.
