FL&WVMIKE
Rube would be proud !
This is exactly like my drawing, and condensed to fit in a small space. It uses a lot of hose clamps, but looks like it works just fine. You can spend more time/money to make it look cleaner, but the result is the same.
I wouldn't call it 'Rube Goldberg' at all.
I would call it effective. Sure beats running the battery dead trying to pump fuel, or sitting beside the road because your 1934 model fuel pump quit working.
Plus, if you don't want to use to the pump, you just leave it turned off. Engine draws through that white (one way) check valve.
