EFI wiring harness
grumpyjc
I'm putting a 1990 5.0 EFI motor in a 47 Ford. Who makes a wiring harness to plug everything in to make it run?
Just a heads-up, that you are in the "Questions and Suggestions Forum" section here.
This section is more for questions about this Ford Barn Forum.
You might get better response if you list this in the "Discussion" section here,
in the "Late V/8" section. ;)
I did the same exact swap and used a "DETAIL ZONE" HARNESS. Look them up in streetrodder magazine, it worked awsome!! first time I hit the key the fuel pump ran and the engine started right up
hope that helps,
john
Fer cripes sake, why would you dig this old tread up from the grave. :confused:
It is OVER a year old and the original author only has 4 posts, so he
hasn't been here seeking anymore updated info about his original question.
Cover it back up with dirt, and let this post rest in peace. :eek:
