E EAV8 Member Mar 1, 2017 #1 How do you tell If the steering gears in the Model T Ford steering column are 4 to 1 or 5 to 1? Thanks
29spcoupe Well-known member Mar 1, 2017 #2 The 4 to 1 gears have no markings, while the 5 to 1 gears have a 5 on them. If you want to change the gears, you must use the correct pinion for that set. The pinions for the 4 to 1 are different than the 5 to 1.
T tmodelman Well-known member Mar 2, 2017 #3 You can count the # of teeth on the pinions. Attachments IMG_2414 (800x650) (740x601) (700x569).jpg 232.1 KB · Views: 23
