Fred K-OR
Thanks in advance for info on this subject.
Sorry I maybe could have found out how to lubricate the speedometer cable in one of the books I have but thought maybe someone on here may have a neat way to do it. So thought I would ask.
If I remember correctly, a person if they want to remove the cable, has to pull it out from the end attached to the speedometer? Is this correct? Then you can do your thing as far as lubrication. Then the question is, what type of lub should a person use? Oil, grease, etc.?
Or can a person just take the end off the speedometer and squirt some 3 in one oil down the tube?
Anyway just wanted to find an easy way to do it. My speedo seemed to flip around this morning when I took it for a drive and I am thinking it needs a least the cable lubed.
