B bobscogin Senior Member May 9, 2012 #1 Re: '28-'29 running board splash shield. Could someone give me the measurement from the center of the rear most mounting hole to the rear edge? Thanks, Bob
Randy in ca Well-known member May 10, 2012 #2 Bob, here's a couple of pictures that will hopefully show you what you need. If not, or you need anything else I can easily check again. Attachments Splash apron holes 001.jpg 59.3 KB · Views: 44 Splash apron holes 002.jpg 69.6 KB · Views: 41 Splash apron holes 003.jpg 77.5 KB · Views: 45
B bobscogin Senior Member May 10, 2012 #3 Randy in ca said: Bob, here's a couple of pictures that will hopefully show you what you need. If not, or you need anything else I can easily check again. Click to expand... Randy - That's exactly what I need. Thanks for your help! Bob
