Early master cylinder ID
Pandersen33
Anyone recognize this master cylinder? Looking to replace it as its obviously leaking. Its a 2-bolt so a little different from the genaric juice-brake masters. I just need something that will fit
Thanks.
I have it brand new --- but not with the screw type lid, but with a standard bale wire lid ...
Call me --- 516 - 485 - 1935.... Long Island, New York.... Craig....
Thanks.
Your M/C 'LOOKS' like the one BELOW. But rather than "just needing something that will fit", you should be more-aware of the diameter of the bore, with an inclination toward matching the bores. Using a M/C with as little as 1/16" DIFFERENCE in diameter of the bore can considerably alter the feel, as well as the amount of force required to push on the brake pedal to match the performance of the M/C that you now have.
Below is the M/C that I found that appears like yours. Click the link BELOW for information on that particular M/C. DD
https://www.ebay.com/itm/3847538595...xg%3D|ampid:PL_CLK|clp:2047675&epid=236499040
485470
485472
Not an early master but looks like a GM dual master that someone cobbled up for use as a single hanging master on early firewall.
I think it is plumbed as a dual. Note thin pipe coming from banjo on forward fitting.
Fire wall should also have some reinforcing on the inside or my guess is that will eventually crack as they are not thick enough on its own
51 MERC-T , I think you are correct. Looks identical to the 67 Camero master cylinder my brother used on his 1957 Nomad.
Looks like a bracket assy. is bolted to the firewall.
485506
OPPS ! guess I need to look at all the pictures before I open my big mouth ! thanks 51 merc
