OK, tell me how to recognize a 2-tooth that will bolt in my '28 and allow me to use my '28 wheel please. Thanks.
ALL 2 Tooth steering are KEYED. Your spline wheel WILL NOT WORK with 2 tooth.
You have a couple of outs to get 2-Tooth steering.
1. Purchase a complete 1929 "Gemmer" 2-tooth steering including "open sectors" spark and throttle lever setup. You will need a 1929 Black (or Red) keyed wheel. This would be closest to what you have now. You may have to do a COMPLETE REBUILD of this steering box as it has the non-tapered cone bearings which were obsoleted and replaced with taper rollers about August 1930. You will need to examine your box for functionality as a non-taper bearing may be shot - or it may not be. Mine is not shot and I'm still going.
2. Decide to "mix & match" and settle on a 2-tooth steering column from a 1930-31 Model A but which is more likely have a "rebuildable" 2 tooth box - which may or may not need rebuilding. As this box/column will have "closed sectors" at the top and a different wheel than yours now, it will be a decided change - but possibly a cheaper change since the box rebuild if required is more likely to be routine.
It really is not possible to FORCE FIT a 1929 keyed wheel onto a keyed 1930-31 column as the column lengths are different and you may have interference or stick-out. So you really can't swap parts between 1929 and 1930-31 in a steering column/wheel mix/match to seek the cheap way out.
According to the Judging Standards the five following 2 tooth steering units were used
1. Gemmer/Pat.Pend in raised setters
2. Gemmer/Pat.Pend in sunken letters
Both of these were used from Feb 1929 through May 1929
3. Gemmer/Patented in sunken letters
This one used April 1929 through mid 1930
The units above are most likely to have the 1928-29 style "open sectors" column which you want. I would assume all of these are "non-rebuildable."
4. "A-3550-C" in sunken letters
5. "A-3550-C" in sunken letters and "F" in raised letter.
Both of these used Jan 1930 through end of production
SOME of these are NOT rebuildable - the change came in August 1930 - but all have the 1930-31 column and wheel.
Hope this helps.
Joe K
