Early Ford emergency brake cable guide tube replacement.
paetsgone
Has anyone ever had to replace the emergence cable guide tubes on a early Ford. My tubes are rotted off and I don’t think anyone sells these. I guess I have to bend up some tubing of the correct size, but if anyone knows the best way forward, please let me know.
I've done it, just used a flairing tool for tubing to make a flair on the end to hold the rubber dust boot in place. I think the tube size is bigger than common lines at the parts store, but I had an old chunk of hydraulic line that was perfect.
I make them out of hyd tube; bend them a little, flare the end, and I braze on a washer for the boot stop. Pretty easy process.
At one time, either Cling's or Snyder's made and sold them.
thanks
You can get the exact tube size through McMaster-Carr. I did so many of these I had purchased a 3' piece.
