Early Brake Cross shaft (Solid)
moasew
Hi:
I''m looking for the first solid brake shaft used with the left side emergency lever. It is item number A-2485-ER. As you can see in the attached photo it is the same as the one used later however it has an extra clevis for the left E Lever. If you have any leads let me know otherwise I'll go with the three piece cross shaft /dogbone I have in the car now and try to make it as good as possible.
