FirstA
My project today was to remove the drive shaft from the 28 banjo to check the bearings to see if they needed replaced. I discovered that this drive shaft does not have a sleeve that the bearings ride on. The pinion has to be removed to get the drive shaft out. This must be an early 28 axle thing. I have read the forum about removing the pinion from the banjo on later axles. I assume this would take the same method but thought I would ask first. The bearings feel good from spinning the drive shaft. Maybe I will just adjust the preload and leave well enough alone. All comments are welcome!
