Early 28 brake equalizer shaft
mrtexas
Are there sprigs associated with the early 28 brake equalizer shaft(dogbone)?
Where does A2483 brake cross shaft socket springs (9/16” long; 7/16” diameter) go?
Pictures?
at each end of the 'dog bone' where they rest in corresponding sockets of the cross shafts
Where did you get the springs? What is the gauge of the wire?
Doesn't look like my shaft would hold a spring. Are my cross shafts no good?
The hole is 0.54 at each end.
Where did you get the springs? What is the gauge of the wire?.
I was fortunate, my springs were original and intact in the functioning brake equalizer (adding a dab of grease to them will keep them in place while installing). I don't know the wire gauge and cannot get to mine as they are installed. (I don't recall who i 'stole' the pictures from or i would give them credit):confused:
One of mine was broken so I scrounged around for a replacement. Not positive but I think I cut down a valve spring from a Briggs and Stratton engine.
I finally got around to installing the above-mentioned springs. As suspected, there were no springs installed previously. They were a little bit of a pain to get into the U-Joint housing sockets but once in they definitely take out play and tighten everything up.
an FYI for the next time around.
if you need that spring in the end of the 1/2shaft. the one in the camshaft plunger is the same diameter, it just needs to be shortened. i think you can make 2 out of that one spring.
