Early 28 brake cross shaft
talwrench
Started working on my 28 roaster p/u. I encountered a different cross shaft than I have seen. Its 3 pieces. My question is, dose anything belong between the shaft and the U clamp where it is supported out at the frame? I have lots of movement front to back. Should note this is early, no seperate shaft for emergency brake, the e brake pulls on the 4 wheel brakes.
No, it is just the shaft passing through the bracket. The shafts are typically worn right where they pass through the bracket. I recently had some welded up. Yes, this brake system was kind of floating to equalize between the 4 rods.
Thanks for the diagram. Thats how my three piece brake shaft is, but I don' have seperate emergency brake system. Looks like all that is there is the support brackets at the frame. Going to rework them to take out the excess play.
There is alot of play on the early brakes. Equalization
